Omron HMI NS8 not proceeding beyond "Connecting..."
strikom
Oct 2013
Karachi
21
Greetings all!
I am relatively new to the world of OMRON HMI. I was using the NS8 a while back and accidentally I transferred a program to the HMI that was actually meant for the NS5 model. Now when I start the HMI (connected to the computer) it does not move beyond the black screen with "Connecting..." on it.
Is there any way to correct this so that when i start the HMI i can access the HMI settings etc.
Please, the need is urgent.
Kind regards
Welcome to the forum.
The "Connecting" message is indicating the NS is trying to connect to a PLC.
You should be able to download the correct program using CX-Designer.
You can also access the HMI menu by touching two opposite corners of the screen. Example upper left and lower right corners.
Hope this will help.
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
886
Hi all, I have a customer that has a series of around 15 Omron CJ1M PLC's, each connected to an Omron NS8 HMI via an ETN21 module. The PLC and...
2,918
Good afternoon, I need to create a recipes display on the hmi ns8, to change the parameters of a servo and some strings . The PLC that im using is...
2,772
I have an Omron NS8-TV01B-V2 that will not start up. Has an error warning. I tried to create a program in CS-Design and down load to a flash card...
3,713
Hello friends, Can I seek your expert advise, I am new to Omron HMI/PT interfacing to Omron PLC. My question is how to communicate this to? 1...
3,676
