omron nt20s problem help!!!
mordehay
Jan 2017
netanya
Good day to every body
I am trying to replace old touché screen [omron nt20s-st121-v1]
To new one [[omron nt20s-st121b-v3] they look identical and the Manuel show they replicable]
I use nt tool software that i install from cx0ne file. i upload the data and screen graphics from the old one
And I see it on my pc. But i cant download it the the new one,,
I see massage on the pc: [download aborted please refer to error log]
The error log write many error like:: memory utilization has exceeded the 96,00 Kbytes limit by73.68kbytes
Small applications that i wrote just for checking go well and download
i wonder maybe it the nt tool but all the other application from that disk cx one work good [plc + hmi +servo ]
i hope someone help
I use the omron NT20S touch screen to control a system that must "open" and "close". At each end there is a feedback to an input from the PLC...
4,296
I have a machine with an Omron Sysmac CQM1 PLC & NT20S HMI. I got the NT software installed on a VM & the OEM files, it opens OK. I also have...
2,448
I have two of the same units that are using a CPM1A and an NT20S-ST121B-EV3. I am not able to connect to the touch screen as far as i can tell via...
3,999
Hi, I'm learning to program my plc with hmi nt20s ,do someone has a program example? many thanks, JuGa
1,367
Hello! What software is needed to configure this panel? The NT Series Support Tool doesn't work (communication error when I try to transfer...
8,965
