Omron nt20s-st121-v1 hmi
fons04
Nov 2007
Quebec
69
Hi, is the Omron nt20s-st121-v1 hmi can be programmed with a tool on CX-Programmer package? If not wich software is needed to perform on it? Thanks
NTST is the programming tool for the NT series screens.
This program is located on CX-One CD #3 under the Utilities directory.
Not sure where it is located on the DVD version.
Hope this will help.
I have a machine with an Omron Sysmac CQM1 PLC & NT20S HMI. I got the NT software installed on a VM & the OEM files, it opens OK. I also have...
2,452
Good day to every body I am trying to replace old touché screen [omron nt20s-st121-v1] To new one [[omron nt20s-st121b-v3] they look identical and...
1,985
I have two of the same units that are using a CPM1A and an NT20S-ST121B-EV3. I am not able to connect to the touch screen as far as i can tell via...
4,002
Hi, I'm learning to program my plc with hmi nt20s ,do someone has a program example? many thanks, JuGa
1,369
Hello! What software is needed to configure this panel? The NT Series Support Tool doesn't work (communication error when I try to transfer...
8,968
