omron output pulse
If the CQM1 series model is a CQM1-CPU43-EV1 it will support two high speed outputs. If you download and read the manual W226-E1-7 it contains a full description/specification/wiring for pulse output functions.
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
122
Hi, i already make a program CP1E with pulse train ouput (PLS2) to control stepper vexta. Can i use work online simulator in cx-programmer to see...
1,470
Hello all, I'm using a Omron CP1H-XA40DT-D programmed with CX-Programmer V9.3. I have programmed the Plc to move a camera on two axis on top of...
3,235
I'm playing around with the pulse output functions of Omron CP1L and I would like to monitor the output frequency in data trace. I do not see a...
6,510
I am trying to control a rotary actuator using a omron CQM1H-CPU51 with a pulse output card PLB21. With the transistor output units i was able...
3,313
