Pulse train output omron
Windy0812
Jul 2019
Medan
Hi, i already make a program CP1E with pulse train ouput (PLS2) to control stepper vexta. Can i use work online simulator in cx-programmer to see pulse in memori A276,A277,A278,A279? because the cp1e that I ordered hasn't arrived yet
Thanks & regards
No YOU CANNOT!
Just like most PLC's when in simulation mode, high speed interrupts, high speed pulse inputs/outputs are hardware related instructions and require the physical PLC.
Hello, I am using pulse train output to a stepper driver to control a stepper motor. It seems to work fine except when I use a Control Stop...
3,328
There is a machine in my plant with an obsolete Omron PLC in it that I need to replace. One of the outputs from this PLC is to a stepper motor...
5,664
question what is the maximum number of pto outputs you can get if you use a micrologixs series plc? If I can remember correctly, you can get a...
5,618
I am using a Panasonic FPX 14 I/O PLC w/ Transistor outs to control a servo/stepper motor for an automated infeed on a retrofit punch press...
2,882
please tell me how to take pulse train output from ge fanuc versa max micro plc.give me a sample program is it possible to interface a barcode...
4,789
