pulse train output - allen bradley
irondesk40
Jan 2008
nc
630
question
what is the maximum number of pto outputs you can get if you use a micrologixs series plc?
If I can remember correctly, you can get a stepper output module for a slc500, can you do that with a micrologix
irondesk40 said:
question
For the first question, if my memory doesn´t betray me the maximum is 20 khz.
For the second questiosn this is the answer:
http://www.amci.com/plcmodules.asp.
Hello, I am using pulse train output to a stepper driver to control a stepper motor. It seems to work fine except when I use a Control Stop...
3,328
Hi, i already make a program CP1E with pulse train ouput (PLS2) to control stepper vexta. Can i use work online simulator in cx-programmer to see...
1,460
There is a machine in my plant with an obsolete Omron PLC in it that I need to replace. One of the outputs from this PLC is to a stepper motor...
5,660
I am using a Panasonic FPX 14 I/O PLC w/ Transistor outs to control a servo/stepper motor for an automated infeed on a retrofit punch press...
2,880
please tell me how to take pulse train output from ge fanuc versa max micro plc.give me a sample program is it possible to interface a barcode...
4,789
