Omron RS232 Communication With Banner BCR Camera
averellen
Jan 2004
Guelph
112
Hi all.
I have a project with Omron CJ1M-CPU11's where I need to connect 2 barcode readers to each.
I want to use the P4 BCR camera as it works great scanning at long distances.
However I don't know much about Omron other then connecting and working the basic instructions.
Ask me how to do this with AB and a basic module... no problem.
No better time then the present to learn something new.
I figure I need one CJ1W-SCU21 on each CPU.
Anyone have suggestions/samples of RS232 communication using this module.
---Edit---
I also figure I will need to use the CX protocol to communicate with the cameras via RS232.
---Edit---
Also I need to connect these CPU's to the network, then connect to an OPC application (yet to be written). For this I'm guessing I need to install a CJ1W-ETN21.
Am I correct in this thinking?
Any help is always appreciated.
Adam
Is it safe to assume that this P4 bcr camera is an ASCII serial RS-232 camera? If yes, and if the Omron CJ1 can communicate via Ethernet/IP or Modbus TCP, which I believe it can... A product called DeviceMaster UP can sit between these two and facilitate your communications between the two and alleviate the headaches in programming so much more complicated logic.
Feel free to contact me directly for an evaluation unit, or additional details if you might be interested.
Regards,
Brand: motorola Model number: LI 4278 Cradle model number: STB4278 Rs232 cable: CBA-R01-S07PBR To communicate with Plc model: omron CP1E -N30-DR...
2,132
Good day experts! There's an old WinCC system (v4 running on Windows NT) that includes Omron CPUs (SYSMAC C200HE CPU42) which communicates via...
3,723
I'm so embarrassed, I cant find a way to steal K3HB-V data to put to D1500 and D1700. I had CX-PROTOCOL, but :bonkhead: Help me please...
1,910
Hello, I'm currently trying to recieve some data over RS232, using an Omron CP2E with an RS232 option board. The device it's communicating with...
663
go to download 3G2C7-LK201 and RS232 comms with LSS (and SCADA) please you selection a link, after you waiting 5 seconds next skip ads, go to...
1,277
