one Ethernet Module with 2 CPU
eg12555
Jan 2020
seoul
Hi all,
Currently i work on Allen Bradley PLC logix5555
At the chassis there are 2 CPU(1756-L55/A) and 1 EtherNet/IP module.
And i wonder it's possible to communicate with 2CPU by using one EtherNET/IP module.
Well yes, you can communicate with both CPU's using one Ethernet I/P module.
You have to consider the number of Ethernet I/P connections that the Ethernet I/P module can support though. The catalog number of the Ethernet I/P module will determine this.
Hi Guys, I am trying to read data from Omron CP2E CPU from my Mitsubishi RJ71EN71 with Simple CPU Communication Function. Suppose it was using...
1,814
I have 3 GE CPU311's that I would like to tie into Cimplicity PE. I know it is possible via serial connection with SNP multidrop, but will these...
2,455
I have an AB SLC 500 with a 5/01 1k CPU with an open slot. I am looking to place an ethernet module into the PLC for READ ONLY capabilities for...
6,401
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
374
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
434
