mrtweaver
I have been trying to get connected to a Siemens OP27 screen. On power up I use the ESC and UP arrow. Top of screen says TRANS MODE: Press ESC for load mode. So far I am figuring I have done things correct because this is the information that I have found using Google.
Now on laptop I bring up Protool/CS 6.0 with SP3. I go in and check the settings for com port says com 1 19200. All seems to be ok. But when I click on the connect, it take only about 2 seconds and comes back with error message that I should check my cables, my settings, etc...
As far as I know all my hardware is set properly and the cabling pin out I found seems to be the same as what I have.
15 pin 9 pin
3 3
4 2
5 8
10 7
15 5
So did I miss a step somewhere or what am I not in the transfer mode of the OP27 or what?
Thanks for any and all assistance. Have a great day.
15 pin 9 pin
3 3
4 2
5 8
10 7
15 5
