OP7 Transfer mode...
metaller
May 2004
Bratislava
86
Hello there, we have problem with turning the OP7 into transfer mode. After power restart, there is reason to hold right arrow, down arrow and ESC, but after that the memory in OP is erased before turning into transfer mode. Is there any reason to set up OP to transfer mode without erasing flash?
Thanx for any help :eek:)
it depends on if there is a configuration already
within the OP or not.
You can find all KEY-CODES in the manual Chapter 3
HTH
Rolf
This screenshot is from a manual that says "Simatic HMI, OP7, OP17 Operator Manual":
[attachment]
I guess that your version is more correct. But I wonder which manual it is ?
Hi Jesper,
I think it's the same manual.
I found your screenshotin chapter 15.
but maybe....
here the link: OP17
Rolf
Hi, everyone I was thinking of transfering the used inputs and outputs that the user choose to use on the OP7 to the PLC, the problem is that i...
4,225
I have converted a Siemens OP7 program to a new Delta DOP107BV. It is all working as expected except for the timer values. I am using MW36 as the...
956
I have a customer who had a faulty Siemens OP7. They sourced a replacement. They have the original program. I downloaded the program to the...
2,545
Hi Guys, Hoping we still have some Siemens Old hardware Gurus on here. We are trying to support one of our long time customers. Who have obtained...
946
Hi all! I have this old Siemens Simatic op7 panel I need to rescue. At boot nothing appears on lcd, backligth and all led's are on. Does not...
791
