OPC server for modbus RTU
apetkov5
Aug 2007
x
101
Dear all,
I nead OPC server that will be able to connect several modbus rtu devices (slaves) trough RS-232 and collect datas from it.
First device is connected to COM 1
Second device is connected to COM 2
Third.....
After that I will connect SCADA to this OPC and get collected data....
I have tried Matrikon OPC for modbus, but when downloaded i can not start installation ? so I nead some other OPC to install it...
What is best OPC server for mine situation ?
Best regards!
Hello,
> can you sugest me what to use and where to find it
Yes, go to the website linked under my name, and look for MODOPC.
Dear all,
Third.....
Best regards!
what scada system? most have some sort of serial modbus driver included.
thanks mark,
also i got a question since this is my first OPC interface to make, but i already made the IO list for the DCS now my question how these tags will be refelected on SCADA, do i have to make similar IO list on SCADA, or the OPC interface will take care of that....plz i need ur advise urgently....
Hello,
It depends on how the OPC server is implemented. The OPC specification does not cover tagnames.
Generally an item in an OPC server has a tagname and an item ID. The item ID is the ‘source’ address in the device the server is reading/writing. The tagname and item ID can be the same.
The OPC client connects to the server via the tagname.
Again, it depends on how the OPC sever is implemented.
"scada" system is wincc flexible 2008 sp2.
It has modbus driver included, but i can configure just one connection. I can connect it to device connected to COM 1 on computer, but i can not connect it to another device that is connected to COM 2 on same computer...
have you thought about buying a port server like a digi or lantronix? it would be cheaper to buy one or 2 of those and then use the included modbus tcp driver in the software package. Most people are going away from using serial ports on a pc for scada.
Hello,
>... it would be cheaper to buy one or 2 of those...
Cheaper than $29.00 for a MODBUS OPC DA server?
well, it will be not directly connected to "real" serial ports...
modbus device, with rs-232 port, will be connected to transparent gprs modem.
gprs modem will be connected to pc with fixed ip adress.
pc run programm called port redirector, that make virtual com ports...
scada engine will be connected to that virtual com ports. (over the opc)
Hello,
Based on your last description, I assume each device has a unique slave ID.
If so, then in MODOPC, I would set up the ports to use the RS-485 driver. Then it will poll each device in order. The port redirector should not know any difference. Configure it for the one serial port.
Otherwise, in MODOPC if you set up each slave device as using a 232 serial port, MODOPC will attempt to poll all the devices concurrently. And I think that would be trouble, depending on several factors.
Hello,
seams logical.... i will try to do it.
so shall i do next:
- configure just one port in comport redirector (serial port is defined only by tcp port)
- each gprs modem to connect to defined ip adress and just one defined port (defined tcp port that replicator put to serial port)
- set each device different modbus slave adress (device one: 1, device two: 2,....)
or you mean something else?
Hi, I have some ladder application which controls motor drive.Right now i have connected PLC with KepexServex with ethernet tcp/ip.Now i have a...
2,082
Basically I’ve got a Modbus RTU device (Nemo D4-L meter) with RS485 connections. I’ve connected to it over Ethernet using a RS485 to Ethernet...
4,442
anybody have experience with matrikon opc server products? I am looking at using one for a huge project that will have approximately 500 rtu's and...
2,556
Hello, I start this post based on a simple problem: communication between some devices and WinCC over Modbus RTU network (protocol). Believe it...
5,450
hi If the manufactor of the plc says that his PLC supports modbus protocol , does that mean that I can use any ( modbus ptotocol OPC server )...
6,710
