open loop tension control
dhiru
Aug 2009
NOIDA
i am doing a project in which i have unwind a paper roll , for this i have contol the tension using brakes , i just have following information ..
  1. diameter of roll
  2. width of roll
  3. density of paper
can anyone tell me the equation for finding tension using these parameter .
thankyou.
I have a winder that we use to rewinder paper at our paper mill. The way we check tension in the roll (to avoid a soft roll) is to see how much of a razor knife blade you can push into the roll. If you can get less than 1/4" its tight enough for us (recycled medium mill 58" roll diameter).
We run the pneumatic brake on our winder to the torque of our winder drives (drum winder with shaft). We used to use load cells, but this would produce a nice tight sheet with 2 less pieces of equipment to brake.
I use a PID loop in ControlLogix to vary the signal to the I/P to the pneumatic brake so that the wiinder will run consistent tight rolls. The nice thing on this set-up is that when the brake is running at 100% for 50% of the roll, a message is displayed so the operator can check the brake pressure on the gauges (make sure no air leak) and get the mechanics to change/shim the brake pads.
hi to all, i am doing a project in which i have unwind apaper roll , for this i have contol the tension using brakes , i just have following...
3,187
Hello All Could we get some expertise on flow control ? -Using a PID loop in Productivity 2000 with an analog output, How can we convert...
19
1,606
We have to do a positioning with an incremental encoder on the motorshaft that delivers 6 pulses per rotation. One rotation of the motor is 22.8...
2,172
I don't understand how vfd detects speed when we are running in open loop control (sensorless). For me only possible way; during auto tuning it...
2,676
Good Afternoon , I am getting ready to refurbish 2 machines . It will have 3 SEW gearmotors on each machine. I would like to keep the...
3,733
