Positioning with open loop speed control
aand74
Dec 2005
Deinze
131
We have to do a positioning with an incremental encoder on the motorshaft that delivers 6 pulses per rotation.
One rotation of the motor is 22.8 mm of the end actuator.
This will be done with a drive that has no encoder connection (open loop speed control). Resolution of the encoder would not allow it anyway. We will read in the encoder with encoder card on plc. We will do the positioning with some logic in the plc (S7 1500 Siemens), no technology object will be used in the plc.
Positioning does not have to be dynamic.
Accuracy has to be +-0.2 mm on target position.
I have some doubts because the speed loop is open, so low speeds are Always difficult.
Does this seem realistic?
You have 3.8 mm per encoder pulse. Your encoder isn’t a high enough resolution to fit your tolerance, and even then you have a host of other issues.
there could be a lot of variables but I would think this would be possible. We have done this several times with SEW hardware. They have a motor with a 96 ppr pulse counter that we have used open loop positioning. We have had success down to +/- 1 pulse. but to do that we have logic that calculates the error and is constantly finetuning itself. So the first run or two during startup are always not as accurate till it calibrates itself.
Hello, I feel stupid. Have been reading about PLCOPEN for motion control but do not quite get the connection to the hardware. I want to do a...
1,900
The system of position control is quite different in Beckhoff compared to Siemens. In a Beckhoff controller with Beckhoff drives on Ethercat, the...
856
I'm working on a SCADA project in FTView SE where there are many instruments, each of them has a Faceplate that can be called by a "Go-To Button"...
561
Hi, I am using P&F - WCS reader to read position of a trolley motion on a crane. Sometimes there is Ethernet communication failure error given by...
1,045
We have a project with a couple different fairly simple positioning tasks. Speeds are fairly slow and positioning doesn't need to be super...
2,036
