Positioning with PLCOPEN???
Karsten
Feb 2006
Odense
158
Hello,
I feel stupid. Have been reading about PLCOPEN for motion control but do not quite get the connection to the hardware.
I want to do a very simple positioning with a motor drive that excepts a +/-10V command from an AO. I have a linear sensor 4-20mA connected to AI.
This is just for test/demo and no speed or accuracy demands.
In general terms how to use this haedware with the plcopen FBs?
I the plcopen function blocks are provided by the hardware(motion controller) manufacturer. They are specific to their hardware. They may look the same(from vendor to vendor), but it is really firmware. The function blocks are inherently made for positioning types of applications where you don't have to worry about feedback and analog signals. Please explain in more detail what you are trying to do.
PLCOpen blocks are used by for example codesys to have a nice platform and good portability between systems.
You can contact zaltbommel for this, but i know you use wago codesys, and they have this is their libs.
for your app i would NOT use them as they are too complicated for what you are looking for.
or use oscat
setpoint -position := output;
and yes this simple will work, it will oscilate but it is a start.
The system of position control is quite different in Beckhoff compared to Siemens. In a Beckhoff controller with Beckhoff drives on Ethercat, the...
857
I'm working on a SCADA project in FTView SE where there are many instruments, each of them has a Faceplate that can be called by a "Go-To Button"...
562
Hi, I am using P&F - WCS reader to read position of a trolley motion on a crane. Sometimes there is Ethernet communication failure error given by...
1,045
We have a project with a couple different fairly simple positioning tasks. Speeds are fairly slow and positioning doesn't need to be super...
2,037
Hi, I'm stumped with this. I'm attempting to perform some positioning using a Powerflex 755 series VFD. First time I've done something like this...
3,533
