Operating System - Windows 7 or 8
Charbel
Jan 2012
Beirut
307
dear,
i will buy a laptop and it has an Windows 8 as operating system, the problem with windows 8 is that it has many bugs and i dont like the interface.... but this is the future... what do to? shall i downgrade to windows 7 which is more reliable or stick to windows 8 which it will be upgraded to windows 8.1 soon?
thank you for your advice,
charbel
For what it's worth, I've not had any issues running under Windows 8. While the Metro interface is more suitable for touchscreens, utilities like Classic Shell will let you boot to the Desktop and give back the Start Menu.
In fact I use Classic Shell on Windows 7 machines, because I prefer the XP style Start menu.:)
Depends also on which software you intend to use.
Siemens software is only released for Windows 7 for example.
Hi!
If you are going to work with old software I would choose Win7.
Regards,
Bruno
This is not to say your stuff will not work on Win8. The major issues I've seen compatibility-wise has been getting things to work on a 64-bit system. There's generally less trouble installing on 32-bit systems, but that doesn't mean I'm going to shy away from a 64-bit system just because I don't want to take the time and effort... Heh. Sorry, started on a rant, and I'm going to stop now.
Interesting discussion...
Would a Windows 7 Pro 64 bit VMware machine with Siemens Installed work OK under Windows 8 host?
I cant initially see any issue with that.
Windows 8 Pro includes Hyper-V so as long as you have a Windows 7 license you can run Windows 7 as a virtual machine without installing any other software.
I have had good success with Hyper-V.
Thanks.
It would be intel i7 and 8GB ram for sure.
Hyper-V sounds interesting also
Cheers
dear,
charbel
It doesn't have many bugs, you just don't like the metro interface. I'd like too see evidence that Windows 7 is more reliable...anyway.
If you don't like windows 8, Window 7 Pro is the choice. Pretty easy decision I think.
Just checked up on Hyper-V.
This is a quote from Wikipedia:
Just something to be aware of.
I haven't played with it, but the Settings for Hyper-V in Windows 8.1 *does* have provision for two Comm Ports.
There isn't USB support, but apparently there are software and hardware solutions. Not sure I would be satisfied with this if I needed USB, so my suggestion of Hyper-V might be premature or unworkable...
According to this article, using enhances session mode will allow access to local USB devices. Granted, the example given is a flash drive, but may be worth looking into.
In the meantime, VMWare or VirtualBox does provide USB support.
I was pretty excited about the possibilities until I saw that the only guest OSes supporting enhanced sessions were Server 2012 R2 and Win8.1 Go figure.
I'm working on a Schneider TSX Micro TSX3722001 with an alternately flashing ERR and TER led. The machine has been idle for about 3 years and I...
995
Does Rslinx, rs500, rs5000, studio5000, have drivers for Windows 11 pro. I'm in need of a new laptop for programming with all of this software. I...
4,258
Hey Guys, I have a B&R 2005 (IF260) PLC with no operating system. My PLC Parts: 3IF260.60-1 (CPU Module) 3IF672.9 (Interface Module) In order...
1,532
Hi In the project that is attached to the file. I want to add a new OS. Why is the connection to the Ethernet network interrupted by connecting...
2,029
Hello, My desktop pc is used for OPC and take values from many PLC to measure downtime. i did a upgrade in the Rslinx, now i have installed...
3,115
