Operator Taught Sequence - Controlling Cylinders
gclshortt
Dec 2014
Ontario
3,217
The following is a post that was recently done. I thought that I would share...
We will program a sequencer controlling seven cylinders that can be taught. The cylinders can be operator programmed from the AdvancedHMI screen. You will be able to select what cylinders to activate at each step and program in 500 steps. Our PLC will be the Do-More from Automation Direct.
We will be using AdvancedHMI to communicate Modbus TCP to the Automation Direct Do-More Designer Software Simulator.
The following is the sequence of operation:
Watch on YouTube:
https://www.youtube.com/watch?v=In_W5SyWWBU
The following is the explaination of the code:
Watch on YouTube:
https://www.youtube.com/watch?v=n63sXqUkjN8
To see the set by set development and the code visit our website.
http://accautomation.ca/building-a-plc-program-that-you-can-be-proud-of-part-6/
Let me know what you think.
Thank you,
The original program was for a tube bending machine. This was done with an Omron PLC. This version also has additional indicators on the cylinders to determine the differences between the input step sequence. This feature is good for troubleshooting the machine.
Watch on YouTube:
Regards,
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
722
Hello All, We have assembly line and our supplier building automated line on top of it we are interfacing mes system. Our automation supplier...
285
Has anyone setup comms between an operator terminal expert hmi (model doesnt matter) and tia portal? Cant find much on the web. There is a small...
860
Hello, When trying to enable the Operator Control & Monitoring features in Data blocks of the Step 7 5.7 project it gives the Error of Operator...
921
Hello everyone, we need to use android tablets that simulate Rockwell's panel views (tablets will be replaced by hmi which are having very long...
3,507
