Hello, I am having an issue with an OSR bit starting a rotary indexer.
Running AB studio5000 on a 5069 L320ER v32.1
I have 13 inputs before an OSR instruction. the output of the OSR instruction is to start a rotary indexer logic. i have used this practice on multiple machines with no issue.
this particular machine seems to not respond the same way.
the logic before the OSR is all true, and the output bit seems to never go high as the indexer does not respond.
I have tried using the output bit to latch a bit to start the indexer and breaks the latch when the drive responds.
the machine will run for about 15-25 min then hang up waiting for the output bit to start the logic.
Does anyone have any input on this?
I have attached the code. I am on the greener side when it comes to machine programming.
Any help is much appreciated!
Edit:
Second picture added of PLC in hangup state.
Edit:
