OT: European abbreviations "./."
jdbrandt
Oct 2002
Pennsylvania
1,203
SET Off_Topic_Warning = ON
Can anyone here tell me what the Europeans (Germans, in
this case) mean when they type:
I've seen it in spreadsheets, and it seems to indicate
either Not Applicable, or Data Not Available.
SET Off_Topic_Warning = OFF
Hi folks, I have encountered two different plants (Both having Siemens PCS-7 control systems) where the tags/symbols for the Equipment was...
2,052
I am supplying a control system to Singapore. The range of AWG wire size for the main breaker is 3/0 to 500 mcm. How do I put this in European...
2,740
In my experience, most of the control panels I have seen here in the USA require 480 VAC, 3 phase and (typically) no neutral is required/supplied...
3,733
I have a washer/dryer machine coming from Europe which use 400v/50hz/177A. The machines has some heavy blower/vacumm motors that run on 400v, and...
23
6,618
I got a panel in today built in the U.S. and it has Brown wire for 24 VDC + and Blue wire for 24 VDC-. Is this the European standard? I have seen...
17
4,733
