The Plc Kid
I do the same as gmferg but I use this http://www.kensington.com/kensingto...io™-bluetooth-keyboard-and-case-for-ipad.aspx also if I find myself needing to make lots of edits.
I have seen a folding table w/built in chair at Walmart or Target, thought about getting it at one point. Think it was around $20. Would be one of those "use and throw away" deals when the project is done.
I have used the new iPad for the last 2 startups. There are several RDP applications available, we're using iTap RDP. I leave my laptop running all Rockwell and Wonderware software in a safe location attached to the same wifi that my iPad can access. With the iPad in hand, I can walk around all the equipment and get up close to it. I can stroke valves and watch them open and close. I can spin motors and check rotation all by myself. That is your justification. A second tech is less likely to be required. A bonus is that it impresses the hell out of your customers.
One thing that is cool is that you can zoom way in on an iPad. I crawled under a tank to check and zero a level sensor. I had RSLogix displaying the analog input and zoomed in so the numbers filled the screen, 5" tall numbers! I then propped the iPad up on the floor 6 feet away and could easily watch the live readings.
Checking out instrumentation is faster and easier also. I can go directly to a flow transmitter with my iPad, place the xmtr in simulation mode, generate different 4-20mA outputs and read the PLC input directly on the iPad.
A lot of these things can be done with a laptop on the floor but it's just not as convenient. The iPad is compact and light. There is a huge battery advantage with the iPad also. Where you're lucky to get 2-3 hours out of a laptop battery, the iPad can go a full 10-12 hour shift with moderate use.
The negatives:
1. Wifi will not always be available and the plant may not allow you on it. Even if you bring your own, they may not let you attach it to their network or even power it up in their plant.
2. Program editing is not easy to do on the iPad. You are RDPing to your laptop with an iPad that only has a touchscreen for input. It is difficult to scroll and type. It really works as an HMI for your graphics and a viewer for RSLogix. You can do edits but it is not easy and is very time consuming. Go back to the laptop to do PLC edits.
3. The iPad doesn't have the horsepower to run your programs on its own. You still need your laptop but at least you can leave it setup in a safe and comfortable location.
The iPad is another tool to have in the box. It also provides entertainment on the plane and in the hotel.
How about connecting via an ad-hoc network directly to the laptop's wifi?Wifi will not always be available and the plant may not allow you on it. Even if you bring your own, they may not let you attach it to their network or even power it up in their plant.
I got a kick out of one of the "Specifications" for that table...
Yes, that should work assuming the laptop is within range. Our customers typically install main PLC cabinets in MCC rooms on 2nd floor and Ethernet remote I/O down on the floor. We've utilized this cat 5 which is isolated from the plant network and installed a small switch at the PLC end to share connection with laptop and on the floor connect a wifi access point/switch for iPad wifi access.How about connecting via an ad-hoc network directly to the laptop's wifi?
Alas, I have resisted joining the Apple cult, but I may have to get me one of these damned iPads after all...
-Eric
Have a look at the new Micrsoft Windows tablet that I mentioned previously - it really does look pretty good.
So? It is still very new and not released yet but shows great promise - that is all I said.Is that the same tablet that locked up during the microsoft presentation last week?
Locked up? No, that's just another one of the wonderful new Windows 8 ergonomic features. It forces you to take a break every 30-60 minutes.Is that the same tablet that locked up during the microsoft presentation last week?
Battery Type: Does Not Contain a BatteryNo battery? In a table? Really? Who knew?...
-Eric
