OT - limit/lock from lift
_Woody_
Jan 2008
Auckland
119
Has anyone seen anything remotely like this? Apparently it is a door lock on a lift with some contacts to indicate to a control system. This is on a boat and may have been manufactured in Germany circa 1990.
Looking to source replacement or spares without having to re-engineer the whole thing.
Looks like a basic spring loaded limit switch.
Actually its kind of the opposite. It appears to be a mechanical lock / bolt with a set of notification contacts as to he position of the bolt. For the application I would expect the lift door to be closed and locked before the controls will allow the car to move.
I have seen something similar on a lift door
Check your local yellow pages for
Elevators Escalators Lifts
My suggestion would be Otis or Schindler as I think
they were the firm that did our annual maintenance
Yeah it is on a lift (on a boat) I am looking into the elevator companies as well but its proving to be difficult without a brand or part number. Thanks
Based on the probability it was manufactured in Germany, try 'http://www.kronenberg-gmbh.de'. They have many similar looking offerings, but the number of options available will make finding a match without a part number tricky.
Good luck!!
Brilliant - thanks for your help guys. I am pursuing the kronenberg switches that look to be very similar to the old unit. Did also find some Schmersal door locking devices but not quite the same.
Thanks again
Hi, I want to write a logic, I have total 6 analog input of temperature and have 1 drive. Now i want to start drive when any one of 6...
1,604
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
91
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
105
Good evening all! I hope you folks are doing alright today, as I've got a situation that I believe I've come up with a solution to but I wanted to...
447
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
214
