OT: WinXPsp2 Icons in Win Explorer
504bloke
Jan 2005
Down South
2,721
Hi
Laptop Dell D820 WinXP Sp2 brand new
Fully up to date (Windows Update) running IE 7 etc etc
When i open up windoze explorer in the right hand pane where the files are - all files (and for that matter directories) show with an Internet Explorer Icon next to them ?
I cannot find where i can change this so the programs show with there proper icons ?
Any clues would be welcome as this is very strange and i havent come across it before!
That is weird...so what do you see when you go to Tools --> Folder Options... ---> File Types tab?
EDIT: You might also look under View --> Customize This Folder ... and hit the Restore Default button there. You would have to do this for the entire directory structure, but you could test it at least to see what happens in one particular area...
A heap of extensions with there associated icons as it should be
Done that already, just tried it again in case i made an error, still got IE Icons on everything
It only appears on the D drive though (CD/DVD) the C drive shows icons properly?
Also whilst viewing the D drive folder directory if i hit F5 then in a millisecond the folders/programs show the correct icons then they get overwritten by the IE Icon ??
This is my autoroute (2nd) cd
Typical, all was looking good.........
Did the Microsoft KB steps, all icons restored....
Until you reboot then its back to square one all IE icons :(
Hello, I am new to control expert and I am looking a quick start guide for basic ladder and function block programming. I have searched the web...
1,564
Hi guys, i need an animated SVG water pumps and tanks to use them in Scada system, i didn't find an animated SVG they are all without animation...
4,376
Hello, I have experienced some strange behavior from an automation line with WinCC based HMIs. A sequence would not progress until I basically...
2,250
I cannot see the small icons in the valve faceplate FB73, so to click them for access to Maintenance view. I am working on Siemens CFC v8.1 and...
1,628
Hi, This maybe a stupid question, but can someone explain why some processors appear as just a processor, and others look like they're part of a...
2,196
