output pulse display
sheryl86_ann
Jul 2008
laguna
142
Hi!
I am using [dplsr k12000 k3750 k50 y0] to run the motor. I am using a sensor to make it stop after rotating 180 degree. I want to monitor the corresponding exact value the motor runs. Does anyone here know what relay/ data register to use? Or any command? I dont have a display for output unlike servo amplifiier, im only using a motor drive and no 7 segment display there.
And, Any formula to compute the 360 revolution? ON how to get the exact value for my K3750 (pulse) and or K12000 (frequency).
Thank you very much.
Sincerely,
sheryl
When online,click right the mouse,enter the soft organ,then enter d8140 d8141,then click start monitor,that's ok.
my english very poor,so..........
Hi!
Thank you for responding.. What do you mean on soft organ?
Also, you mean I will out value on my d8140 d8141? Sorry I cannot understand...Please explain further(sorry)..Thank you very much!
Sincerely,
sheryl
I cannot upload the pictures here,so I don't know how to explain that.
I'm sorry!
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
191
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
125
I am monitoring two BMXDDO3202K digital outputs for their behaviour, they are each for opening and closing, and so the on time affects how far the...
293
Hello, I am using pulse train output to a stepper driver to control a stepper motor. It seems to work fine except when I use a Control Stop...
16
3,355
Hi all, To make a long and annoying story short, a client has two flowmeters in their water plant and the flowmeter that controls the CL2 dosage...
2,366
