Outputs
gbradley
Apr 2002
Corona, Ca.
1,637
Where can I get information on TTL open collector outputs?
I want to build a sorting machine with an interface that has TTL open collector outputs.
Interface is a 36 Pin Amphenol plug, and each pin corresponds to a different bin.
I think the drive voltage is 5V?
My ignorance is glaring!
Thanks for any responses.
OC outputs
Do you mean that you have devices in your sorter which need open collector outputs to drive them or do you mean that some devices in the sorter have open collector outputs which you must bring into your PLC?
Thanks Eric those links are awseome.
I havn't even chosen the PLC yet.
I don't think I've worked with this type of output before.
I want to somewhat understand the mechanics of the comparitors outputs before I choose the PLC to use for this sorter.
My sorter is an old HP LCR comparator.
I'l be sorting inductors.
I've got some reading to do.
Thanks again
George Bradley
123
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
292
Does anybody know how 'timestamp output' functionality internally works in a controller? I do not mean the instructions you use as a programmer...
72
Hello, I am stuck on trying to get an ArmorBlock, 1732E-16CFGM12QCR to respond to EIP outputs. My PLC is Panasonic FP0H-C32ET. I Registered the...
149
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
854
