panel view 1000 communication
bioplc
Jul 2005
tampa
97
We have a Panelview 1000 touch screen (color) connected to SLC 5/05 thru 2711-NC13 cable (Channel 0) and Channel 1 is Ethernet.
I was able to connect to PLC with Crossover cable and i expected panelview in the network..but i did not see panelview. So i tried to connect panelview using 1747-UIC [RS232 (DH485)]<----> 2711 NC13.
no luck yet...
can any one explain..where i am going wrong??
thanks in advance
Be specific ! Be clear !
Rule #1: Always post the exact part number of the PanelView terminal you are using.
Only the part number will allow anyone to tell you for certain whether to use the 1747-UIC (if the terminal has DH485 protocol) or a straight-through serial cable (if the terminal has DF1 protocol).
First get the serial port configuration and PanelView cabling right, then you can work on the SLC-5/05 passthrough.
I purchased a used PanelView Plus 1000 to learn get familiar with the software. Seems to be a pretty popular HMI. I can ping the HMI but I cannot...
903
Hi ya´ll! I want to take a backup on the HMI and opened up Factory Talk View Studio - View Machine Edition v12.00. First thing i notcied was...
1,369
When I see the Kilogram data on the electronic scale indicator that changes quickly and smoothly, but Same data on panel view plus does not change...
1,275
Hi; At our one of machines, there is Allen Bradley panel view 1000. The HMI was working fine but after a power cycle, it failed to build...
4,633
I have a customer who has multiple PV Plus 1000's. These run Firmware 5.1 and Window CE. I need the serial numbers off of the software that is...
1,543
