panel view 1000 plus
Hi friend thanks...
I have a factory talk view studio in my laptop but i can't go online with my panel view....
You know what can do it...
I hope your comments
Um, you can transfer the program via a usb key, a compactflash card, hook up to it via ethernet.. Not sure what your exact issue is?
As most of the touchscreen are, Panelview Plus are another dump terminals. You can't program them online. For PV plus, there are more steps to perform though.
1. Create your screens, alarms etc.
2. Assign your tags, either thru an offline file or online.
3. Assign a start up screen and other necessary startup objects
4. While online with the PLC, choose the target PLC
5. Create the application file [.mer file]
6. Download to the touchscreen.
If you can get someone familiar with PV plus is an advantage to reduce your learning curve.
Else, standby enough nasty words and go through the above steps.
Best Regards
____________
I purchased a used PanelView Plus 1000 to learn get familiar with the software. Seems to be a pretty popular HMI. I can ping the HMI but I cannot...
891
Hi ya´ll! I want to take a backup on the HMI and opened up Factory Talk View Studio - View Machine Edition v12.00. First thing i notcied was...
1,350
When I see the Kilogram data on the electronic scale indicator that changes quickly and smoothly, but Same data on panel view plus does not change...
1,273
Hi; At our one of machines, there is Allen Bradley panel view 1000. The HMI was working fine but after a power cycle, it failed to build...
4,596
I have a customer who has multiple PV Plus 1000's. These run Firmware 5.1 and Window CE. I need the serial numbers off of the software that is...
1,540
