Panel View 1000
If you have keys, press the right and left arrows. If its just a touch screen, then a Screen Selector object should have been put in somewhere by the previous programmer to get to the Config Screen.
If a standard PV1000 touchscreen, reboot and watch for the little square on the lower right hand side. Press this square to get into the config screen.
alabaowoyemi said:
Guys, pls can you tell me how to change or setup screen in PV1000
I'm not sure how the previous posts construed that this person wants to get to a "configuration" screen.
What do you mean by "change" or "setup"? If you wish to change the appearance or set up a new screen (or any screen if this is a brand new unit), you will need the software. Please be more distinct in your question...
I purchased a used PanelView Plus 1000 to learn get familiar with the software. Seems to be a pretty popular HMI. I can ping the HMI but I cannot...
905
Hi ya´ll! I want to take a backup on the HMI and opened up Factory Talk View Studio - View Machine Edition v12.00. First thing i notcied was...
1,374
When I see the Kilogram data on the electronic scale indicator that changes quickly and smoothly, but Same data on panel view plus does not change...
1,275
Hi; At our one of machines, there is Allen Bradley panel view 1000. The HMI was working fine but after a power cycle, it failed to build...
4,650
I have a customer who has multiple PV Plus 1000's. These run Firmware 5.1 and Window CE. I need the serial numbers off of the software that is...
1,544
