Panel View 300 question
Soggy Canuck
Jan 2008
Vancouver
229
I Have an existing PV300 talking to a SLC5/03. The client wanted an additional writable parameter added in. No Big deal right? I modified the PLC code to suit and proceded to add in the WRITE, NOTIFICATION, and HANDSHAKE Tags to the PV application(using Panelbuiler 32). Downloaded the application no problem.
When I called the numeric entry and attempted to write to the PLC I get the following Error Code: "ERROR 208 Unable to write to remote device".
Does anyone know what this means?
Thanks Soggy
Thanks for the reply.
I did look through the knowledgebase and saw the same files, the power supply shouldn't be an issue - it worked fine both before and after I changed the PV300 application, the addressing I have checked twice, I am using the same format as two other existing numerical inputs.
I suspect this will turn out to be another of those subtle settings issues that seem to catch me whenever I go back to a system I haven't played with for a few years.
In the tag database in PB32, is the correct "Node Name" selected for the tags?
Also, do the addresses actually exist in the SLC?
Those are the only two causes I can think of since it's not a RIO interface...
Paul
Soggy,
Zip your SLC file and the PV program and post here if you can.
Tell us the register your writing to and the tag name of the write tag.
And what screen the write is on.
Someone can help you look.
Good morning, I would have a question to ask you. I have a Micrologix 1100 to which I have to connect a PanelView C300 in ethernet. I have...
2,103
Hi, we are using PV300 and using Panel Builder 32 as software. We are receiving the error code as 31. Please let us know how to clear this error.
7,962
i have a panel view 300 whos cat no. is 2711-k3a5l1 i am using comm'' cable 2711-nc13(rs232)cable when i connect it to pc and pv 300 after that i...
7,858
Hello all, I have a panel View300 - Model: 2711-K3A17L1 B A 4.41 (AB) By connecting it shows me 'ERROR 40' - Manual Error 40: Error firmware (...
5,270
Hello everyone! I'm trying to hook up two HMI(panel view 300) to the same PLC (micro logix 1500) using the same port as the other port is connect...
3,500
