Panel View e Transfer and PV1400
PAC
Guest
P
I use “Panel View e Transfer” to transfer file: XXX.pvc (the program file for Keypad )to the PV1400e terminal.
The transfer did not succeed. There are caution window show the following message:
|Unable to access specified file C:\xxx\xxx.pvc |
|Cause: SHARE.EXE was not loaded, |
|or shared region was lock.(11) |
| (Error 4100) |
| OK |
Anyhow, I ignored above message and try to download the file to the PV terminal. Finally, transferring succeeded,
I found the xxx.pvc in the PV1400e terminal, but I could not open it
The terminal always shows "! MISMATCHED APPLICATION FILE” when I opened the file.
In the other hand, I used the other project: YYY.pvd (the program file for touch screen) and transferred to the PV1400e terminal. The transfer was successful and could be opened in the terminal.
I’d like to open and run xxx.pvc in the terminal, please suggest how I should do.
Hint: 1. the original PV1400e is touch screen type but the touch screen was damage; therefore, I replaced it with the Key pad.
2. the program for Keypad (xxx.pvc) was created by referring to the original program (YYY.pvd).
3. During the xxx.pvc was transferring, the key pad was connecting to the PV1400e terminal.
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
226
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
289
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
143
Good morning, I have a question, I would like to know if I can send an Excel file to an email from my panel view and see how it is possible to...
164
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
342
