PANEL VIEW PLUS 1250 communication problem
Arakhith
Oct 2016
jharsuguda
I had recently repaired a panelview plus 1250. the older firmware version of panelview was 5.00.04.55 (CPR 9). The repaired panelview came with a firmware verson of 5.10.14.09 (CPR 09 SR 2). The new panelview had communication problem. I changed the devicenet card with a working one. It still had communication problem. I erased the .mer file, reset the terminal, again loaded it with a working .mer file, also ticked the replace the communications while loading the new .mer file. It still seems to have communication problem altough the panelview runs smoothly. Does anybody has any solution to this problem??
Welcome to the Forum !
Can you describe in detail the symptoms of the communication problem ? DeviceNet is more complex to use with the PV+ than some other protocols, so any information you have about error messages, indicator LEDs, or status messages from other devices on the network (like if there's a PLC-mounted DeviceNet scanner), that would help solve the problem.
First, check out the node number on your devicenet card. Make sure the node number is set up properly.
Do you have access to View Studio ME by chance?
Devicenet both the LEDs are healthy green. I have checked the devicenet node ans baud rate in panelview settings it shows correct. as defined in devicenet confirgation file.
I have checked the devicenet module in a running panelview. It worked fine.
Could it be possible he may need to recommission the network so the new device has the configuration file?
Another panelview with firmware version 5.00.04.55 (CPR 9) with same node and confirgation, and same .mer file was working fine in the same network.
We have boiler control system runs on A-B PLC. The interface is A-B Panel View Plus 7, mounted on the local control panel very near the boiler...
205
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
315
Good morning, I have a question, I would like to know if I can send an Excel file to an email from my panel view and see how it is possible to...
189
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
380
I purchased a used PanelView Plus 1000 to learn get familiar with the software. Seems to be a pretty popular HMI. I can ping the HMI but I cannot...
927
