Panel View plus comm problems
smiller
Aug 2003
Arizona/Brazil
116
We have recently built a 345KV substation that is using a SLC5/05 for SCADA control and a Panel View plus for local alarm dislay. We have an extensive fiber network to the substations on property and go through a GE JungleMux SONET system. Are there any known problems with the PANEL View plus units? We experience a drastic slowdown of the JMux node when the PV+ is plugged in to the hub. AB has been evasive but mentioned that there are known memory leak issues and then clammed up about it. I am working with a contract engineer on the problem and haven't been able to make any progress. I have tried a different PV+ and an early version of firmware as well as the latest firmware as provided by our vendor. Does anyone have any experience with this? Maybe Mr. Roach?
thanks
smiller
I think that your PV+ is working as intended. At least, as AB intends Ethernet/IP to work. An Ethernet/IP node will broadcast packets all the time. It is a part of the way Ethernet/IP works.
Maybe you can filter away the undesirable packets by exchanging the hub for a switch (who uses hubs these days ?).
Does the PV+ communicate just with the SLC-5/05 on the local network segment, or with SLC-5/05's on remote network segments through the JMux ?
I admit that I don't know anything about SONET links. I always use isolated Ethernet networks for control systems.
PanelView Plus has had it's share of challenges, but I fail to see how some hypothetical memory problem would result in excessive network traffic. There's nothing special about the PVP EtherNet/IP driver that does any broadcasting or multicasting (it's strictly EtherNet/IP Class 3 messaging traffic, as far as I know), so the traffic between the PV+ and the controllers is only what you ask it to be.
Check the "Display Update Rate" for each PV+ display, as well as update rates for any trends. If you have the update set for 50 milliseconds, for example, that might produce a lot more Ethernet traffic than your inter-segment link can handle.
What sort of tools are you using to examine this system ?
I heard before that an Ethernet/IP node would broadcast in order to query for new connections. Maybe I am wrong.
edit: But even if it doesnt broadcast, if it is connected via a hub, its messages will arrive at all the attached network nodes.
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
281
Good morning, I have a question, I would like to know if I can send an Excel file to an email from my panel view and see how it is possible to...
157
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
334
I purchased a used PanelView Plus 1000 to learn get familiar with the software. Seems to be a pretty popular HMI. I can ping the HMI but I cannot...
888
Hello, hope yall are doing well. I have a HMI program where I need to add a "GoToDisplay" button, so when this button is pressed, it goes to a...
888
