panel view
ayyan74
Oct 2014
Thrissur
hi,
In panel view +6 1500,I cant do the language switch.when i export the text file it is showing as english text,not translated text.anybody can help me
Regards
Did you carry out the original translation? (you know that FTVIEW doesn't actually do the translation for you right?). I normally design the application using English as my base language, then you export to spreadsheet - carry out the required language translation within the spreadsheet, then re import to your project. Add language switching buttons to one of your screens, and you should see it toggle between your selected languages.
Hope this helps.
Regards,
Rob
Hope this helps.
Regards,
Rob
Thanks a lot
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
208
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
283
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
141
Good morning, I have a question, I would like to know if I can send an Excel file to an email from my panel view and see how it is possible to...
160
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
339
