HMMMM?
See help quote below. As you said its still unclear to me. Only if you selected "Write to Controller on Start-up"
5 If you selected Write to Controller on Startup, specify what values to write to the controller.
Select: To:
Use Terminal Presets: Write initial values set by application
Use Last Terminal States: Write values present prior to power-up. This is the default.
Note: Preset values for objects are set in the object’s dialog. These values override initial values entered in the Tag Editor except for numeric entry objects.
Allen-Bradley Company, LLC, Copyright © 1993-2002, All Rights Reserved
AB Knowledgebase # 17492
Mickey: Sorry, man. I misspelled your name.
That's the line I was looking at. It will save data values over a power-cycle, if you so choose. Most of the machines I have around decide for themselves
what initial values should be, so I don't generally have that turned on. This is the line that could use clarification:
"These values override initial values entered in the Tag Editor except for numeric entry objects. "
After some experimentation, I'm going to guess that it refers to the "Initial State" setting that does NOT appear on the Numeric Entry object dialog. A dead end?
Wildcatherder: Have you tried saving the file with your values intact, and editing that? (as opposed to re-upping the original editted file repeatedly) ? I'd guess yes by now, but it's worth a try...
I don't have any PV's to experiment on right now.
Anybody like Rockwell's "New" Knowledgebase search engine? (!)
17492 - Error:
PanelBuilder32 - Unable to load file. Not a PanelBuilder file or file is corrupted or disk space is low
Problem/Symptom:
Application is running in the PanelView.
Whilst attempting to Upload the PanelBuilder reports the error:
"Unable to load file. Not a PanelBuilder file or file is corrupted or disk space is low."
"Failed to open document."
Cause:
An attempt was made to open the PanelBuilder Application (.PBA) file with an older version of software. PanelBuilder (.PBA) files can only be
opened with the same (or higher) version than it was created with.
PanelBuilder 32 (PBA/PVA) files are not backwardly compatible.
