PanelMate 1100 Download problem
AJ_25
Mar 2010
New York
I have a PanelMate 1100 that works. When I attempt to download a new configuration I receive an error "Station is not a 4 button unit". I was told that it might have a bad battery so we change the battery with the same results. Any ideas?
I can't be exactly sure but it sounds like the configuration file does not match the unit you are trying to download to and the unit is rejecting it thinking the config file is for a "4 button unit". Is this config file something you created with s/w? If so, I would double check the settings to insure they match.
In these cases then I start by working in reverse, remove each change working back to the originalthat worked. That usually weeds out the offending change.
oh, and welcome to the forum.
There are some issues with some PanelMates (though I don't know if it's that particular one) where it will forget what it is. It basically happens when the CMOS battery dies and it goes back to some "default" CMOS configuration. Unfortunately, it's not a fix that you can perform in the field...
The interesting thing is the 1100 is a 4 button panel. It must no longer think that it is still an 1100.
I have experience with 1700 and 3000 which are both 4 buttons and had to convert a 5000, which is a 5 button, to a 3000 where all the 5th button configurations are dropped. (PITA)
Hello all - I am looking to modify some existing PanelMate 1100 applications for a downtime collection project. I just opened the applications in...
3,229
I am in the process of replacing a panelmate 2000 with a 1100 series. I can get the config to load, but when I try to connect to the PLC (TI435)...
1,625
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
531
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,278
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can...
1,159
