Panelmate power pro 1700 - Recovery mode.
Redouane
Apr 2012
Jeddah
Hello,
We are facing one problem for a Panelmate power pro 1700 that it start on Recovery mode, we try to download the Executive firmware power pro as the manual said, but we can't, the panelmate hung on a message: Query:Rtc and the software give fail on status.
So please did you have any idea about this issue, and how to fix it?
Many thanks.
Are you sure that your serial connection is good? Can you try it with a known good, working PanelMate?
Once that is proven, I can only suggest that you try to send the firmware at a slower serial baud rate.
It has been many years since I worked with the PanelMate products, but I do recall on rare occasions having problems with serial communication errors, and slowing the baud rate solved it.
If none of these suggestions helps, then the only other thing I could suggest would be to send it away for repairs.
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
524
Hi Everyone I have a faulty Cuttler&Hammer Panelmate I need to replace with a AB PanelView. I managed to transfer the .PPS file from the unit but...
18
4,992
Good morning: I need to migrate/convert an application (6 Kb size) from Panelmate Power Pro 1775T PMPS 1700 to a PanelView. I have the current...
26
8,627
Hi, I'm glad for the opportunity to find this forum. Found it by accident, wish it had happened long ago. :) I have a Panelmate 1775 and the...
2,561
Cant seem to get Hmi to transfer with transfer utility also tried doing the serial port tests with a loopback plug and both ports still come up...
1,612
