PanelMate Power Pro Password issue
Ratt
Apr 2009
Waterloo
I have a new (to us) machine that has a Micrologix 1500 controller and communicates to a PanelMate Power Pro interface. We actually have 2 of these machines that are virtually identical. The problem I have is with the PanelMate... there is a password on adjusting the motor speed. We cant figure it out. The other machine we guessed it as 1111 however we've tried all obvious combinations and no luck on the second machine.
My main delima is I have nothing to communicate with the PanelMate. I do however have RSLinx and RSLogixs 500 and 5000 software. Not only do I not have the PanelMate Pro software/cable I do not have the funds to aquire them currently. Is there any way to defeat this password? I'm hoping there is a High Level password that I can use or something of that nature.
Thanking you all in advance for any help you can lend me/us!
Rob
Your best bet is to contact the equipment maker/previous owner to find out what the password is.
It is possible that they are using the PLC to handle password protection, in which case you might be able to find it in PLC code. But the PanelMate internal passwords may not be accessible at all without the programming software.
I would still suggest you try to get backup copies of all the software used on your machine in any case, so that your PLC code will have comments.
If you are required to maintain the PanelMates, you will eventually need the software to do so, which will make it very easy to retrieve the built-in passwords.
Paul
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
520
Hi Everyone I have a faulty Cuttler&Hammer Panelmate I need to replace with a AB PanelView. I managed to transfer the .PPS file from the unit but...
18
4,988
Good morning: I need to migrate/convert an application (6 Kb size) from Panelmate Power Pro 1775T PMPS 1700 to a PanelView. I have the current...
26
8,625
Hi, I'm glad for the opportunity to find this forum. Found it by accident, wish it had happened long ago. :) I have a Panelmate 1775 and the...
2,559
Cant seem to get Hmi to transfer with transfer utility also tried doing the serial port tests with a loopback plug and both ports still come up...
1,611
