PanelMate Power Pro Software
Steve Crotty
Apr 2002
Kingston
202
Hi, I have never used the PanelMate Power Pro Software, and I do not have a PanelMate in front of me to test this on. I was hoping that someone could confirm that this logic is correct (I dont want any surprises when I get to site).
I have an air dryer with a run status (000800, and a alarm indication (000801) coming into the PanelMate. I want to change the colour of a status box based on the two addresses.
What i am unsure about is the && (Logical AND) operator. The help is a bit fuzy on how to use it with two bit adresses.
State 1: ([PLC1,800] = 0) && ([PLC1,801] = 0) ---> Red
State 2: ([PLC1,800] = 1) && ([PLC1,801] = 0) ---> Green
State 3: [PLC1,801] = 0 ---> Flashing Red
Thanks,
I'm using Panelmate Power Pro S/w right now:
State 1: ( ~[800] ) && ( ~[801] )
State 2: ( [800] ) && ( ~[801] )
State 3: ~[801]
PS: Your expression will work fine and is equivalent. the above is shorter for bit testing.
BTW, state 3 wlll never be displayed because of the priority. Unless you intended to show state 3 when [801] is set. Then use
State 3: [801]
Usually i put the alarm bit on state 1 and then start the rest from 5 down.. I have had alarms not show up becouse it was a lower priority than soemthing else
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
519
Hi Everyone I have a faulty Cuttler&Hammer Panelmate I need to replace with a AB PanelView. I managed to transfer the .PPS file from the unit but...
18
4,986
Good morning: I need to migrate/convert an application (6 Kb size) from Panelmate Power Pro 1775T PMPS 1700 to a PanelView. I have the current...
26
8,621
Hi, I'm glad for the opportunity to find this forum. Found it by accident, wish it had happened long ago. :) I have a Panelmate 1775 and the...
2,559
Cant seem to get Hmi to transfer with transfer utility also tried doing the serial port tests with a loopback plug and both ports still come up...
1,611
