PanelMate Power Pro Software
Tim Ganz
Dec 2010
Dallas, Texas
689
I am trying to use PanelMate Power Pro Software to make a minor chnage to an epro PC application
I have the PanelMate Power Pro Software and the existing application with lots of CSV files and the main application seems to be this .PPS file but I can't get the software to open it. Does anyone here have experience with this software?
As Gravedigger2 has hinted, the .pps file is the compiled version that runs in the HMI. You need to import that file into the PanelMate Power Pro database to be able to make changes. Once you have made your changes, you must then export from the database to a .pps file before you can write the changed .pps file to the HMI.
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
516
Hi Everyone I have a faulty Cuttler&Hammer Panelmate I need to replace with a AB PanelView. I managed to transfer the .PPS file from the unit but...
18
4,980
Good morning: I need to migrate/convert an application (6 Kb size) from Panelmate Power Pro 1775T PMPS 1700 to a PanelView. I have the current...
26
8,598
Hi, I'm glad for the opportunity to find this forum. Found it by accident, wish it had happened long ago. :) I have a Panelmate 1775 and the...
2,558
Cant seem to get Hmi to transfer with transfer utility also tried doing the serial port tests with a loopback plug and both ports still come up...
1,609
