PanelView 1000 Communications
Secpcb
Jan 2015
Detroit, Michigan
136
I want to add a Panelview 1000 (we have a couple stripped from old controls) to an existing SLC5/03 for displaying faults. Each PV1000 has a RS-232 and a RIO port.
I am guessing the RIO was for the operation and the RS-232 for programming.
Can they operate through the RS-232 to a DF-1 port on a SLC5/03? Or only program through it? No open slot on the SLC, or RIO adapter laying around here.
Please provide the complete catalog number of your PV.
If it is as you stated then the RS232 Aux. port can only be used for programming the PV or configured for a printer.
Sorry for the delay. I took a little time off at the insistence of the doctor at the clinic.
The PV is:
2711-T10G1, Ser D, Rev A, FRM 4.43
Your out of luck see my post #2
You would need a RIO scanner for your SLC5/03 to connect to your PV.
Hello again from cold and blustery mid-Michigan USA. I'm using a PV1000 communicating via RS-232 to a SLC 5/05 processor. I'm ready to...
1,385
I am having trouble getting a panelview 1000 to communicate with a slc 5/05 processor. All is on a ethernet network. Both units are plugged into...
24
21,578
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
141
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
216
Hi All, I was wondering if it is possible to use parameter files that can be passed to a second page eg: --HOME ---PUMP 1 FACEPLATE (With...
1,139
