PanelView 550 screen saver
solder jockey
Sep 2002
Is there anyway to change the text or add a graphic to the PV550 when it goes in to backlight timeout mode?. I find the "screen saver mode" text a little boring
Read the Panelbuilder HELP file
Not on a PV550.
Some models of Panelview DO allow you to pick a graphic.
I'm not sure which ones do/don't. Go to the Application Settings | Advanced tab. If there's a setting for picking a graphic as a screen saver, then that model supports it. If it's not there, then the model does not.
ScreenSaver
How many screens can you have?
What if you had 3 or 4 screens that were just slightly different.
When the PLC isn't doing anything, you can step from one screen to another.
Screen 1
--------Screen2
-------------------Screen3...
Screen1
I know this doesn't save the backlight or whatever, but you can have fun.
I've got a cracked screen on a Panelview 550. Will AB just sell me the screen or does anyone know where I can get just the touch screen? Thanks...
4,256
I currently am trying to write software for an SLC 5/03 & Panelview 550 Touchscreen. I've sorted out all the cables and have it configured...
5,820
Has anyone had problems with thier touch screen getting dead spots in the upper portion of the screen? Is this always a hardwareproblem? I'm...
24
10,376
P
Is there anyway to adjust the default 8 high x 16 wide PanelView 550 touch screen grid? I want to try and fit just a couple more touch sensitive...
10,827
PLCSALES
P
Hi all, Im having trouble transferring a program from one panelview 550 to an new one. I can insert a flash card into the old panelview and upload...
20
348
