I have a PV600 (2711-B6C5) that has a single RS232 serial port that only talks (and apparently is restricted to) DH485. I have built my application in PanelBuilder32 and can't for the life of me download it. I've tried both straight from the PC via serial (null modem) cable and also tried going through the PLC's serial port (configured for DH485) via my EtherNet/IP RSLinx connection to the PLC, but it can't see the PanelView.
Does this unit need a special cable of some sort? I've done a fair amount of googling and can't find much info about this specific model.
In PanelBuilder I've got the application configured for the proper model number, catalog and revision numbers. The terminal is set to node address 2, max 32, at 19200 baud. The PLC node address is set to 1.
When I go to download, the possible paths I'm offered are:
DF1 point to point - internal com 1
DF1 point to point - internal com 3
RS Linx Network
Remote IO pass through
Nothing works, it just fails to even check the terminal. Going through Linx seems promising until I get to the serial port of the PLC where it shows as channel 0, DF1 even though it is configured in the Logix program as DH485.
Any help would be appreciated. Thanks.
RS Linx Network
