Panelview 600
alarsen
Sep 2010
Denmark
Hello
Need a little help. I will work with an AB Panel View 600 Cat: 2711-B6C8 but what cable do I need.
Had thought about a 2711-NC13. But do not know if it's true.
thank you.
I have no rs 232 port on my PC. Can I use a usb to rs 232 converter.
And which driver should I use in RSLinx?
thank you.
Yes a USB to Serial adapter will work. A good one is the "Keyspan" USA- HS19
See link below
http://www.ind-concepts.com/CommunicationData.htm
As long as the RS232 port on your PV is NOT configured for a printer then the DF1 driver should work.
Another method to upload/download your PV's program is a memory card, see PDF below.
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
240
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
489
Hello, Friends Please someone help me find right cable to communicate Panelview 600 (2711-B6C9) to Micrologix 1200 (1762-L24AWAR). AND any advice.
295
Hello , I have an HMI of PV+ 600 (2711-T6M5D) Ser A Rev B, This HMI doesn't have the ethernet port i have to take backup through communicate...
673
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
643
