Panelview Plus 7 / communication
kirk
Jul 2003
Houston
71
I have a CompactLogix 5069-L320ER (has 2 comm ports)
I have a Panelview Plus 7,
Do I have to install a Ethernet switch?
Can I connect directly between 1 port on my PLC and the screen?
And if so, HOW do I communicate/ download to the screen???
Yes, you can plug it directly in.
If your L320ER is configured for Dual IP mode (each port has its own unique IP address), you can download to it via the other port by bridging/routing.
If it is not in dual IP mode, then simply plug your computer into the 2nd port and download.
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
691
Good afternoon, I'm having some HMI communication issues with FactoryTalk View ME. I'm trying to make an update to an existing program that has...
2,551
Hi, We have around 10 PV Plus HMI connected to CLX via ethernet IP-CAT6 cable it was working in good condition for few years but now there is...
1,741
Hello, I am currently installing a PLC control panel and due to space constraints, we will need to install the Panelview 600 HMI separate...
3,379
Hello. I am in the process of designing a new project and I was able to successfully go online with the SLC 5/03 using a 1746-UIC cable through...
1,490
