PanelView Plus 700 Error
magicsmoke
Aug 2007
Minnesota
110
I have a Panelview Plus 700 Cat 2711P-RDB7C ser. C Assembled Terminal Cat 2711P-B7C4D1 Ser. A
I cycled power and on start up I get message
34 Display Module EEPROM Data CRC
ERROR! FEHLER! ERREUR! ERRORE!
I looked in the manual and they don't even have this error listed. Is there any way to recover from this error?
Or should I send it in for repair?
Any one have any luck with repaired PV +?
Error 34 appears to be a EEPROM static error that cannot be fixed by firmware flash. It appears you will have to send it in for repair. See Rockwell Automation knowledge base answer ID #377554. Have never needed to send one in, so I cannot comment on how good the service is.
My Panelview plus 700 HMI stopped working and I replaced it with a new one. Moved the sd card from the previously installed panel to this one and...
1,020
Good day all! I need to make some modifications to a Panelview program. I uploaded it from the unit. Tried to use the Application mgr. to...
1,102
Hi All. I am working on my home automation system again and i am looking at setting up a panelview. Currently running an AB Compactlogix...
857
Hi. I'm working on a plant that has a panelview plus 700. Problem is that from time to time, the alarm list shows an old false alarm instead of...
2,785
