Panelview plus 700 not a valid device
burropardo
Oct 2008
saltillo
25
I have a problem trying to upload a program from a Pv+700 2711-t7c4d1 With firmware 5.0.1 .
The rslinx dettect the ip from my Pv but wen i start the transfer utility And select from the source my panel an error apear And it reads the source selected is not a valid device i attach a pictures from my fault
What version of FactoryTalk View Studio are you running ?
RSLinx Enterprise is the communication driver software used by FactoryTalk View and by the Transfer Utility, and version support is hard-coded into every release. If your software doesn't support that revision of PanelView firmware, you can't upload from it.
It is usually very easy to copy *.MER runtime files onto CF cards or USB drives from the PanelView Plus terminal's configuration screen. That would be my approach.
What you do with the *.MER file once you've copied it from the terminal is a different question. Rebuilding a FactoryTalk View Studio project from a Runtime is not necessarily an easy task.
ftvme v5.0
it is the right version for this pv? any another advise? thank you in advance
I am having the same issue right now I can get my pic to talk to my panelview but will not download keeps saying destination invalid been fighting this for 2 days
You already have a thread going to get help with this issue, please don't raise another thread from the dead or create new posts. It won't help get any more attention, it'll just cause confusion.
My Panelview plus 700 HMI stopped working and I replaced it with a new one. Moved the sd card from the previously installed panel to this one and...
994
Good day all! I need to make some modifications to a Panelview program. I uploaded it from the unit. Tried to use the Application mgr. to...
1,091
Hi All. I am working on my home automation system again and i am looking at setting up a panelview. Currently running an AB Compactlogix...
841
Hi. I'm working on a plant that has a panelview plus 700. Problem is that from time to time, the alarm list shows an old false alarm instead of...
2,741
