panelview plus alarms
cjd1965
Apr 2007
UK
1,659
Hi
I have 128 alarms,set as 4 dints in an array
I have a trigger with L4 etc and created some alarms.
If i generate the plc coil for the alarm the HMI is very slow to respond....maybe 1 minute... before the alarm shows up in the alarm list display which is not good at all
Is there a way of refreshing the alarm list? I was thinking of looking for a change in the alarm DINTS and if a change detected do a refresh
Cheers
Could be a few different reasons for the slow Alarms.
But no, there is no way to trigger an alarm refresh in the PanelView; it does that automatically every X seconds (alarm update rate).
If you show a msec timer value (from the PLC) on a screen, how fast does that update?
ie. is this an Alarm problem, or are communications slow in general?
What network are you using? DH+, RIO, and serial each have their own special limits and ways to optimize.
An overloaded network can make updates very slow.
Are you using HMI tags? Change those to direct reference; specific to FTalkView, HMI tags are slower to update.
I have a system using a Panelview Plus Standard (2711P-T10C21D8S). It is configured with 86 alarms, most of which work fine, but for about five...
2,259
I have a PanelView Plus 1000 Firmware 5.10. The problem is, when testing app in FTVS 8.1 everything works correctly. Downloaded to panelview and...
1,436
Hi guys. I have another problem. This time with PanelView. I am working on project with PanelView Plus 7. It offers just upt to 200 alarms. But I...
2,557
Hey, I'm looking for any guide to create history for numeric input changes using Panelview plus 1000. just simple display contain record of change...
5,392
I am using a Micrologix 1400 talking to a Panelview Plus 400 with firmware 5.10 and using FactoryTalk View Studio - Machine Edition. When one...
3,624
