Panelview Plus 7 Alarms - Pop Up but no Text
naegely
May 2008
Florida
93
I have a system using a Panelview Plus Standard (2711P-T10C21D8S).
It is configured with 86 alarms, most of which work fine, but for about five of them, when triggered, the alarm pop-up screen appears with no alarm message. Also any new alarm I create does the same thing
The panel was initially running firmware 9, I updated to 11 and the issue persists.
Has anyone ever seen anything like this? I have attached the application file if anyone is interested. Alarms 84, 86, 79, 82 and 80 are the ones where no message appears.
Thanks for any help,
Rob
So, A couple things come to mind.
1. On the Alarm Object property page, Alarm Tab. Verify that the Alarm Trigger Filter option is not being used. The Filter will only show Alarms that are selected.
2. Maybe you have a value going to the wrong trigger word.
Thanks for both of your replies.
Sure enough, filter triggering was used and several alarms were not selected.
I have never run into this before, many thanks for the education!
Rob
I have a PanelView Plus 1000 Firmware 5.10. The problem is, when testing app in FTVS 8.1 everything works correctly. Downloaded to panelview and...
1,433
Hi guys. I have another problem. This time with PanelView. I am working on project with PanelView Plus 7. It offers just upt to 200 alarms. But I...
2,552
Hey, I'm looking for any guide to create history for numeric input changes using Panelview plus 1000. just simple display contain record of change...
5,391
Hi I have 128 alarms,set as 4 dints in an array I have a trigger with L4 etc and created some alarms. If i generate the plc coil for the alarm...
1,718
I am using a Micrologix 1400 talking to a Panelview Plus 400 with firmware 5.10 and using FactoryTalk View Studio - Machine Edition. When one...
3,623
