JaxGTO
I got this batch file from the AB tech support a long time ago. Basically copies the logs to a USB when you plug it into the PanelView.
6.0 firmware and greater:
@echo off
REM *** THIS FILE MUST BE NAMED autorun.bat FOR THIS TO WORK ***
REM get to datalog directory and copy these files to external CF card
REM YOUR_APP_NAME and YOUR_DLOG_MODEL_NAME must be modified to your settings
REM If using a USB Thumb driver replace "storage card2" with "USB Storage"
copy "\storage card\rockwell software\RSViewME\logs\YOUR_APP_NAME\DlgLog\DataLog\*.*" "\USB Storage\"
REM get to alarms directory and copy these files to external CF card
copy "\storage card\rockwell software\RSViewME\logs\YOUR_APP_NAME\M_Alarms\*.*" "\USB Storage\"
copy "\Temp\~MER.00\M_Alarms\MachineAlarms.mal" "\USB Storage\"
echo The copy process is complete
Pre 6.0 firmware:
@echo off
pause The copy process is complete
@echo off
Pre 6.0 firmware:
@echo off
