PanelView Plus macro
Athlonus
Mar 2005
Kansas CIty
Does anyone have a macro to return display to security screen
on auto logout of user? I need something to return to home screen if user leaves display open that requires his login. I am not up to speed in VBA yet, but can modify code.
Athlonus,
There is a simply was of having the panelview+ application auto logout of security screens automatically.
Open your application using RSView Studio and then open the Project Settings editor via your Application Explorer. Goto the Runtime tab and select the "Enable auto logout" radio button and enter some non-zero value (ie: 10 minutes) for the "Inactivity period" setting.
Once your HMI remains idle (no interaction by personnel) for the time period equal to the inactivity period, the application will automatically log itself out of the security screens.
Trying to figure out how to write a macro that looks at the system/user and if it changes write the user variable out to the PLC tag. Anyone have...
3,113
PanelView Plus Macro Help Hi, We are using a PanelView Plus 1500 with a Control Logix L71. There is a series of actions that need to occur when...
2,951
hello, I would like to set a bit on (i.e. statusscreen=1) when I press the goto statusscreen button. How would I set up a macro/script for that...
5,691
I wonder if its possible to switch a language using macros. In my application I'm using PLC logic to select the language, but I don't if its...
2,870
105
