Panelview Plus macro
asterof
May 2007
Califonia
554
Trying to figure out how to write a macro that
looks at the system/user and if it changes write the user
variable out to the PLC tag.
Anyone have one that works
PLC tag is called USERLOG and is a string
You don't need to monitor the system/user tag directly. You can assign macros to any user at login and logout in the runtime security editor.
In fact, you could use the same macro for every user on log in. It would be something like:
{[My_Shortcut]USERLOG} := {system/user}
Cheers,
Dustin
Macro Structure
using 3.x security the macro structure is
TAG ...............EXPRESSION
system/user .......userlog = CurrentUserName( )
SO I created one like this
and added it to the LOGIN entry in the user account
in the security editor, but I am not sure it is correct
Yea that did not work. So how would I enter that expression and what tag would be used
You cant write to the system/user tag, although I'm assuming that's not what you had in mind here in any case.
I dont have any software with me to test this, but i believe all you have to do is put your "userlog" tag under TAG and "system/user" under EXPRESSION. You shouldn't need the =CurrentUserName() piece in the expression.
Hope this helps.
PanelView Plus Macro Help Hi, We are using a PanelView Plus 1500 with a Control Logix L71. There is a series of actions that need to occur when...
2,929
hello, I would like to set a bit on (i.e. statusscreen=1) when I press the goto statusscreen button. How would I set up a macro/script for that...
5,653
I wonder if its possible to switch a language using macros. In my application I'm using PLC logic to select the language, but I don't if its...
2,837
Does anyone have a macro to return display to security screen on auto logout of user? I need something to return to home screen if user leaves...
5,796
87
