Panelview Plus Printing - Install Windows CE Application
TripleJ
Oct 2013
Minnesota
Problem - I will be using a CompactLogix 1769-L24ER-QBFC1B to run a skid and a Panelview Plus 7 Standard as the HMI. The customer would like the skid to print a report for every batch the skid completes. I have made arrays in the PLC to hold all of the data for the reports, and also a screen to show/print the reports. I just get tired of having to always make landscape orientation reports.
Is there a way to install spreadsheet or other report-making software on Windows CE itself and then just use the open program ActiveX control to print from there? I have very little knowledge of Windows CE itself, aside from network setups and the like. Perhaps a portable program on a flash drive?
I have a customer who has 20 of our systems using PanelView Plus 7 Performance Series A terminals. With how hard it is to find printer nowadays...
1,627
Hi All First, thanks in advance for your help. Now, I was asked to print a label that says basically if the process was ok or not, a zebra...
1,877
Greetings, Panelview Plus has a print screen capability. I thought this may be an easy way to print a report without using a PC. Simply create...
3,081
I have an application where I have 2 PanelView Plus 1000 HMIs that need to print to the same printer. I have a printer that works USB, but I...
8,074
I have searched the board and also the AB boards, but I can't find anything that can resolve my issue. I am using the print screen set-up on a...
4,220
